Hi guys. Can't I use Smart Ripper to rip the english section of a dvd to hardrive, then burn it with nero?
Have you read a dvd-dvdr guide? answer is yes you can copy dvd to dvdr getting english language only.
Originally Posted by Bman
And i assume you mean the english audio track. -
yeah I mean I read the guide and you need to have all this stuff to make it successful. doesnt the dvd turn from 6 gb to like 3 gb if you take a certain language track and the video from the dvd using smartripper? also, when I do rip it it gives me the dvd files, not ONLY video_ts or whatever. How do I burn these? is there a special way or can I just use nero to burn as a data file?
Hello,
Maybe you should give dvd shrink a try. After you install it click open disc. Then either do a full backup for everything or reathor for special sections. You can also check which audio track you want. Since you have nero it will also load that for you after ripping.
Kevin
----If at first you don't succeed, try a different progam------
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
thanks yoda. Im using Ulead Video Studio 8 right now. this is pretty good.
Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybe
By Roberht in forum DVD & Blu-ray RecordersReplies: 8Last Post: 6th Jan 2015, 17:02 -
Solution for burning of DVD
By pboong in forum Authoring (DVD)Replies: 19Last Post: 12th Nov 2010, 09:56 -
4:3 and 16:9 on same DVD - solution
By sergem1 in forum Authoring (DVD)Replies: 6Last Post: 15th Jan 2010, 02:03 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
