I am trying to convert 2 SVCD disks to dvd. I used Toast 6 to save a s disk image but am unable to change any files to .bin. I end up with files EXT, SVCD, SEGMENT, MPEG2 and unable to change any extensions so I can move to VCDtoolsX. Anyone know what I'm doing wrong? Thanks
"Enjoy every sandwich" Warren Zevon
you have to make a toast image of the disk
if you get this you are either 1. not doing it right or 2 mounting the image.I end up with files EXT, SVCD, SEGMENT, MPEG2
change the name of the image from .toast to .bin so it can be seen in vcdtoolx
if the mpeg2 file you claim you have works, as in it can be viewed then there you go - just use that -
no problem. if you can, please keep your topics together, i see you made a new svcd to dvd topic even though its still giong in this one. for future use, keep them together
DVD Workshop 2: Where is the best tutorial for this project?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2010, 09:09 -
HD-DVD conversion tutorial
By heretic619 in forum Blu-ray RippingReplies: 11Last Post: 27th Feb 2010, 21:48 -
DVD to AVI tutorial?
By darkdream4 in forum DVD RippingReplies: 3Last Post: 6th Jan 2010, 01:19 -
BattleStar Galactica ?? edit: It's over now
By stiltman in forum Off topicReplies: 14Last Post: 21st Mar 2009, 10:57 -
Tutorial: Using DVD Shrink to extract ONLY THE MOVIE
By RogerTango in forum User guidesReplies: 3Last Post: 11th Dec 2007, 21:35
