I in the process of selecting hardware for a new comp and was checking out hardware at pricewatch.com. There is a substantial price difference between the 800FSB 3.06GHz Xeon and the 533FSB 1MB 3.06GHz.
I'm guessing that the 533FSB CPU has more cache? Is this going to perform faster encoding that the 800FSB CPU?
Why is the 533FSB more expensive?
Thanks in advance,
VC
This is so much fun!
The extra cache will always drive the price up. Ultra high speed memory like the kind used in L2 caches is still expensive because it decreases the number of usable chips on a given wafer at the fab plant.Originally Posted by videocheez
The larger cache doesn't buy you much when doing sequential work like encoding. It's more of a benefit when doing more branchy work like gaming and business apps. -
Those 1MB L3 cache Xeons are also known as M-0 stepping Xeons (they are M-0 stepping revision cores), or also Gallatins (for Gallatin core). They have all the same speeds as the 533 FSB 512k cache variants but with the higher L3 cache. They are better suited to server and database work since the extra cache is great for that.
The Nocona Xeon has a 1MB L2 cache on it which is pretty much the same. Why the Gallatins are still more expensive is beyond me. Maybe someone with a lot more Intel knowledge knows the difference between the different level caches. -
Have you already chosen a mobo? If you don't NEED 800MHz FSB, you'll save more on the board as well as the chips.
Nothing can stop me now, 'cause I don't care anymore. -
Yes, I'm going to use the Iwill DH800. Thanks to suggestions by rallynavvie. Thanks for the info. guys.Originally Posted by ViRaL1
VCThis is so much fun! -
NewEgg has the DH800 for only $335 now. It's out of stock currently but oh well. Are you planning on waiting until the winter for the next generation of Xeons? I'd highly suggest it if you're going to spend all that money on your system. I had to get processors right away because my other work machine failed so I got 533 FSB Xeons and I'll wait until the next stepping revision comes out to upgrade to Noconas.
Yes, im going to wait per your suggestions. I would like to get started buying a few things now so my wife doesn't notice how much the whole thing cost's. Are there any components that you suggest that I might purchase in advance of the next generation of Xeon's?Originally Posted by rallynavvie
Also, how do you know the name of the names of the next generation of chips? e.g "Noconas" Where do these names come from? and is the Noconas going to be the next 3.06GHz Xeon with the 800 FSB?
Thanks in advance,
The nicknames are the core names given to processors. The 512k 533 FSB Xeons are Prestonias, the 1MB 533 FSB Xeons are Gallatins, and the new 800 FSB Xeons are Noconas. Core names are also used in P4 and Athlon processors to denote different abilities specific to a chip. Usually only used by us hardware nerds
what is the difference between PCM & MP3
By ashe09 in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2012, 08:50 -
Need to compress a video so that it is 1MB/min, what encoder should I use?
By Bob2267 in forum Video ConversionReplies: 44Last Post: 29th Aug 2011, 19:02 -
Video File Size Is 1mb Off
By Simmons in forum Video ConversionReplies: 2Last Post: 15th Jun 2011, 07:20 -
What's the difference in quality between SP & LP modes in MiniDV??
By navi310 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Jun 2007, 12:09 -
Difference between DirectShowSource & aviSource?
By romi7519 in forum Newbie / General discussionsReplies: 4Last Post: 21st May 2007, 13:18
