  1. When I initially setup SVCD2DVD it asked me what type of conversion I would like to default to. I clicked on avi to DVD. I now want to do some SVCD to DVD. How do I change the default. Also, if my SVCD is 2 or 3 disks, do I have to extract the .mpgs and then join them together before I convert? I also understand that I can input .bin files, so that I don't have to extract the .mpg first, is this correct? Thanks for the help.
    avi to dvd? aren't you using dvd2svcd now??? be sure to get svcd2dvd.
