All of these are made from the post your pic thread. Poorer quality than I expected. I'll try to tweak the finer settings.Originally Posted by tekkieman
And finally the perfect thong
Results 31 to 47 of 47
AnonymousGuest
how many photos are you using in your sample set? I know that Centarsia recommends a photo pool of several thousand for optimal results...
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I tried it last night. Maximum grid size for any useful results seems to be about 15x15. With a queue of around 100 picts, results were dismal. Queues of around 2000 produced images that were at least identifiable.
The greater contrast in the master the better. -
I like how my pic ended up in the valley of the muff
You can find your picture in there?Originally Posted by Capmaster
If you look carefully you'll see that the pics repeat and if you pick out only yours you'll see a pattern. One of mine ends up right where the thong is ....you might say, the "sweet spot"Originally Posted by tekkieman
I should see if I can find the image-scraper program I saw recently - grabs pictures from websites automatically. scrape all the pics from dvdrhelp - avatars, screenshots, posted images, the works - and use that as your image pool.
should probably ask Baldrick how much space the images take before I do so...- housepig
Housepig Records
out now:
AnonymousGuest
actually the images take up a surprisingly small amount. He said something like 150 mb.
Didn't he say his entire DB backup was less than 1G? I know the images are separate, but that is still pretty small considering how much we post!
I was amazed too. Even though most of this board is text, it's still a lot of textOriginally Posted by tekkieman
well, if I knew that, I wouldn't have to look very hardOriginally Posted by Dr.Gee
I know it was at one of 3 sites I frequent, I just need to dig around for a few minutes once I get home and look for it.- housepig
Housepig Records
out now:
Does this look like it? http://www.webreaper.net/Originally Posted by housepig
don't think so - I've seen WebReaper, but this was a similar program that only grabbed images, not the whole HTML works.
and I wouldn't recognize it by sight - I've only seen a description, no screenshots. it was one of those "that seems interesting, but what would I ever use it for?" programs that I end up going back 6 months later and digging up...- housepig
Housepig Records
out now:
Well, I just played around a little with an app called WebImage Miner. It would probably do the job, but the trial is limited to 100 pics max. By the time I hit the 100 pic limit, I still had not made it past the ads, had a queue of over 3,000 external links to check, had only finished searching 70 pages, and was only looking for jps (excluded gifs, pngs, bmps, etc)
I figured I'd better stop before getting myself banned!
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 12:04 -
Video collage/mosaic effect
By purplegreendave in forum EditingReplies: 1Last Post: 9th Aug 2010, 04:06 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Video collage help
By alyle5864 in forum Newbie / General discussionsReplies: 0Last Post: 13th Feb 2009, 16:53 -
Photo collage?
By foton in forum Newbie / General discussionsReplies: 6Last Post: 3rd Dec 2007, 05:29
