Anyone know the name of the program that takes hundreds of photos to make up a larger photo.
Results 1 to 30 of 47
AnonymousGuest
Dr Gee.
I use Paint Shop Pro and you can create a canvas any size you want then drop in pics... resize, rotate, crop ect.... a little manual but it works ok.
Not aware of any 'canned' apps for doing it though -
your girlfriend's name is "browser"Originally Posted by Dr.Gee
Here's some of the ones on the list:
AiPictureExplorer
Bravo
PhotoMix Collage
Patchwork
Collage Maker
eXPress Collage
By the way, if your browser is down, how did you get to the forums? -
AnonymousGuest
I searched and couldnt find what I'm looking for. There are a ton of collage programs but none appear to do what I need. I should probably explain further. This program will take many photos and analyze each ones predominate color. It then skrinks these and uses them to make up a target photo. Playboy did a cover like this several years ago.
Do you mean something that takes say 1,000 different photos, and makes a new picture that looks like say a "bunny"?Originally Posted by Dr.Gee
I thought Bravo did that, but I'm not positive. I can research some more of them when I get to the office in about an hour. I have seen the one you're talking about, and swore I had a demo version of one. Just need some time. I'd be interested in it too, so I don't mind researching it.Originally Posted by Dr.Gee
It can be done in photoshop fairly easy...hang on...I'll check it out...
AnonymousGuest
Cool, thanks. That might be good to use with all of the pics people have submitted. I don't think there would be enough though. Might be able to incorporate it into a t-shirt.
There's tons of programs that do that...
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Running out of time before leaving for work, but this one sounds close:
Code:AKVIS Chameleon - Collage Creation Software for automatic adjustment of inserted objects to the target image color range. The tool is extremely easy to use as it does not require precise selection of objects. Copy an object, insert it into another picture, press a button and the object adjusts to the new background as chameleons do - adapting to the new color range and blending with the environment. AKVIS Chameleon is used to insert new objects in a picture, but with much more flexibility and ease than with conventional tools (collage creation). AKVIS Chameleon is also used to conceal undesirable artifacts by replacing them with the nearby parts of the image (similar to the clone tool). The official web-site (http://www.akvis.com) offers numerous examples and ideas on using the Chameleon Plugin application. AKVIS Chameleon plugin is compatible with Adobe Photoshop (tested with v. 5, 6, 7, CS), Jasc Paint Shop Pro (tested with 6.02, 7.04, 8).
If this is what you are looking to do, then it is pretty easy, and is done with masks. -
I want the one in the Santa cap to slide down my chimney
I could have jazzed the edges of the text up to make it easier to read but I was just looking for the effect, not a publishable image.
AnonymousGuestNo, it is more like pointalism. using dots of color to make up a larger picture. Only the dots are shrunk photos. So say you have a photo of dolly. It will look at the predominant color of each photo in a batch of hundreds and use ones that are mostly white(snow,etc) to make up the white parts of dolly. I have an ad that uses this but wont have a scanner until home.Originally Posted by northcat_8
Dr. Gee -
check out Centarsia = freeware photomosiac software.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Thanks Housepig!
Saved me some work, and added a great looking program to the collection!
That's the one! I couldn't for the life of me remember what the friggin program was called.Originally Posted by housepigHis name was MackemX
glad that's hitting the spot - I went looking for photomosaic software a few months ago, and that was the only good freeware I found.
- housepig
Housepig Records
out now:
I'm waiting for the inevitable noob post: "What good is this thread? These programs aren't going to help me get through collage"
Just my bitter, hateful observation of the quality of spelling and other basic skills we see nowadays from HS grads
I understand what Dr.Gee is saying and I know there are a ton of programs out there like that. I just don't know the names. There's a Darth Vader Poster Like that where the picture's pixels are actually screen shots from the trilogy. They also did that with Yoda, R2-D2, & C3PO. Most of R2 was Hoth and Sky-City screenshots. Yoda was Endor and Degoba mostly.
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 13:04 -
Video collage/mosaic effect
By purplegreendave in forum EditingReplies: 1Last Post: 9th Aug 2010, 05:06 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
Video collage help
By alyle5864 in forum Newbie / General discussionsReplies: 0Last Post: 13th Feb 2009, 17:53 -
Photo collage?
By foton in forum Newbie / General discussionsReplies: 6Last Post: 3rd Dec 2007, 06:29
