    Jul 2004
    Italy
    Hi All,
    yes I know that this can be a silly question but I need your help.
    I have different video files in my hardware (divx format) and would like to see them as a DVD in my dvd player.
    I've just bought Nero 6.0 but it seems that there isn't the plugin for MPEG4 therefore it cannot convert and burn all in one and a message appears at the end of the conversion saying that the file cannot be burned in a single DVD because it is too large ( and it is only a film of 700 MB!!!).
    After that I've bought Easy CD: one of my friends was able to convert and burn all in one with this software but I cannot.
    I don't if it depends from the use of rewritable DVDs or from my incompetence.
    Does anyone can take my hands and walk with me through this difficult street???
    Any help is really appreciated
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I would use a dedicated encoder like TMPGEnc Plus to encode to MPEG-2. Then I would use TMPGEnc DVD Author to author. Then I would use Nero to burn.
    I think All-In-One programs are not worth a pinch of shite, but that is only my opinion.
    If in doubt, Google it.
