I recently made a jpeg image into an mpeg2 short intro video using ulead video studio 8. I use it as a first play when authoring with Dvd-lab standard. It plays well on the pc, but on my 4 year old dvd player, it chokes after playing it and won't continue to the main menu. I was wondering if there is a certain setting you should be using when you convert jpeg to mpeg2 so that most dvd players will read it easily? I used 720x480 and 29.97 frames per sec (ntsc), lower field first, constant bit rate of 6000.
Results 1 to 1 of 1
no Video in MPEG Stream Clip
By al2502 in forum EditingReplies: 13Last Post: 15th Nov 2016, 13:33 -
CONVERTING MPEG 4 TO MOV FILE, ONLY FIRST 30 SEC OF CLIP WORK,help please !
By Haymaker in forum Video ConversionReplies: 5Last Post: 11th Aug 2010, 18:14 -
DV video clip won't play anymore
By cajustse in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2009, 15:57 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25 -
create short MPEG video from one JPEG image
By mb508 in forum EditingReplies: 10Last Post: 14th Oct 2007, 07:32
