Hi
I have the second season of supranos in divx and would like to convert them to dvd format without losing any noticable qulity. I would like to know how i can tell how many episodes i can fit onto one dvd as i wont be able to fit them alll onto one dvd.
Thank you for your help
I do the Divx to DVD conversion quite often i.e. converting tv capture clip from Showshifter to DVD. I have Divx codec 5.1 installed. Use Premiere 6.5 to edit, frameserve to TMPGenc and output to PAL DVD format.
Hello,
Also, use a bitrate calculator like this to determine how large your files will be:
https://www.videohelp.com/calc.htm
Thanx for your help.
can you tell me what a good bitrate would be for this situation? -
Hello,
The few divx cds I've made had a 750 or so bitrate on 1 pass and that fit 2hours onto a 700mb cdr. I guess you just go up from there. The calculator has presets for dvd-r. Just play around with it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
No, thats what the bitrate calculator is for. But the higher the bitrate the higher the quality, up to a certain point. the ouput file cannot be better quality than the input file.Originally Posted by ShadoWolf
A Holiday Season Shoutout To All
By budwzr in forum Off topicReplies: 15Last Post: 28th Dec 2011, 23:44 -
Need help mapping season episode to grouped chapters on a DVD
By nzdreamer55 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2010, 17:12 -
Audio on Entourage Season 1
By Swordfish34 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Mar 2010, 15:31 -
a complete season of a tv series on a 4.7 gb dvd
By Sanmaame in forum Authoring (VCD/SVCD)Replies: 2Last Post: 2nd Feb 2009, 20:44 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 01:23
