is there a way to get more than one movie on one dvd disc, without using lots of diferent programs. if so how can i do this.
thanks for your help![]()
Use DVD Shrink V3.0Beta5 if you have DVD sources.
If you have VHS tape or VCD source, buy a DVD recorder.Sam Ontario -
why buy a dvd recorder for vcd source? just make it a dvd compatible mpeg 1
member since 1843 -
If your source is DVD, I would use TMPGEnc DVD Author, so you can create a menu. Burn using your favorite burning software.
If your source is anything else, I would use TMPGEnc Plus to convert to MPEG-2 then use TMPGEnc DVD Author, so you can create a menu. Burn using your favorite burning software.If in doubt, Google it. -
i use dvd2one or clonedvd. where going on a trip so i wanted to put more
than one movie on one blank dvd. for are lab top.
thanks again
Very easy to do with DVD Shrink
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 02:53 -
DVD Shrink disc freezes in Win Movie Player
By visionman in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2010, 09:12 -
Empty DVD Disc with a movie on it ???
By macbuz in forum MacReplies: 8Last Post: 8th Jan 2009, 13:42 -
Help:How to author 3 disc vcd movie into single dvd without reencoding
By devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 04:40 -
LG DVD-R 4.7GB/ 120 mins. 1-8X DVD Disc with 2:28.52 movie
By Gerald Sr. in forum Authoring (DVD)Replies: 4Last Post: 12th Nov 2007, 17:09
