ok i understand the concept of vcd, i dl them and burn them
i found discs that work and a burning speed
ok now i run a 1.5 gig p4
its brand new
what programs are good for xp
i want to borrow rent movies and turn them to vcds
how long will it take on my machine
and what programs do u recommend
for xp
prefeably easy ones
Well first of all i hafto say it's illegal to rent and copy movies ...
But anyways...
DVDDecrypter 3.0 / SmartRipper 2.39 ( For Copy/Decrypt the .vob files to your harddrive )
DVD2AVI 1.74 ( To Convert the audio from AC3 to WAV and create a frameserving .avi file )
TMPGEnc 2.01 ( To open your .d2v file from DVD2AVI and the WAV and encode to VCD/MPEG )
http://www.doom9.org has the programs mentioned above - good luck!
For Q/A priv msg me.
//Regards daemon
dvd ripping
By maxone71 in forum DVD RippingReplies: 3Last Post: 22nd Mar 2012, 10:36 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Help in DVD Ripping?
By itsjamesd in forum MacReplies: 6Last Post: 9th Nov 2010, 13:55 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
HD DVD Ripping
By joco200 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2007, 15:14
