  1. I've had search here and on the net but cannot find an answer to this question.
    I wish to back up a DVD to DVD+R, using DVD Shrink which is fine but the DVD does not have any Chapters, which I would like to put on the DVD+R back up. Is this possible and if so what can I use and how do I do it.
  2. You need to use an authoring package. Nero Vision Express, DVD-Lab (i imagine) TMPGenc DVD-Author, etc. etc.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    TMPGEnc DVD Author can do it.
    If in doubt, Google it.
