  1. Member zootedlooter's Avatar
    Jul 2003
    BrooklynUSA
    high guys
    i just finished converting with svcd2dvd and i didnt create any ifos or bups.....just vobs....i ran it 2x to make sure with the same results....this is the second time this has happened to me.......
    on this occasion i converted a pal svcd to a ntsc dvd compliant mpg with tmpegenc plus....could this be the cause?...its also happened twice when i let svcd2dvd run right from the bin..one of the times i reran it and it came out ok.......ive converted about 15 other files with no problem...
    is there something i can do to fix it?....also is there something i can do to prevent it?
    looter
  2. Member zootedlooter's Avatar
    Jul 2003
    BrooklynUSA
    ok....i ran it again..and the files were created this time.......
    has anybody else had that problem?
    looter
