I have a Lite-on 5005 dvd recorder.
I downloaded the firmware from http://www.softwareunlimited.co.uk/firmware.aspx (I stay in Malaysia and the TV system here is PAL) to eliminate the macrovision.
Later burnt the file(without _modified) on a CD-R and CD-RW but the recorder automatically ejected the CD. Sometimes it stated 'data disc' on the screen and nothing happened
Please help!!!
Results 1 to 11 of 11
Did you select "NO Multisession" on the cd-RW?
I get the "data disc" message only with cdR, even when it's finalized. -
zleepy
Thanks for the reply.
I selected NO Multisession but still the recorder ejected the disc or showed 'data disc'.
Can you attach the image file of the CD that you have successfully hacked?
Thanks again! -
I'm USA's NTSC and I used my disc for something else.
I'm guessing that when you do a FAST erase of the cdRW, Nero keeps the data disc format.
Try a FULL looong erase, I forgot what nero's name for it is.
Good Luck -
reflash official
Hi Zleepy,
I'm using the full erase function in Nero but still produce the same result: "Data Disc" or ejecting the CD out. You faced such problem previously?
lordsmurf,
What did you mean by reflash official?
Thanks. -
I have no more guesses.
In desperation I make this wild guess - is the file on your cdrw compressed or zipped? -
I was having the same problems - but found that when i checked my serial number it indicates that i have a version 0085. My 5005 model is dated June 2004
on the web site the newest version of the firmware that can be downloaded is 0075 that i can see..
im wondering if i can go back a version or have to wait till someone gets a hold of the 85 to make things work...
im really only interested in the 3h mode right now, and would appreciate any insight. -
clackman,
I think there are quite a few of us with later manufactured 5005 units,
(mine is also dated June) that are waiting for a new hack.
Just have to sit tight for now.
The Devil`s always.....in the Details! -
I had the same problem with the 5001. I found that I had to upgrade through the versions of the OFFICIAL firmware first and then apply the hacked firmware.
Macrovision Firmware Lite-on LVW-5006
By drewbert73 in forum DVD & Blu-ray RecordersReplies: 36Last Post: 9th Sep 2012, 11:05 -
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 03:45 -
Problem installing Real Alternative Lite.
By csh in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2010, 12:24 -
LITE-ON LH-20A1H Problem
By mn072065 in forum DVD & Blu-ray WritersReplies: 11Last Post: 12th Jul 2008, 13:02 -
Lite on HD-A740GX input question/problem
By Dekaspace in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 19:32
