I have VCD which I can not play on my DVD player(Pioneer DV-434) I have other VCDs which works great. This VCD works fine on computer in media player 7.1 but for some reason it would not play on DVD player. I have codefree DVD player, but I do not know which format the VCD is in may be this is a problem...Can any body help me
Thanks in advance
As you have played selfmade VCD's before on your DVD Player, see what the difference is between the one that doesn't play and the one's that do. Is the disk clean? Did you use a different type of media? Did you change the process is someway. Sometimes it will work if you use VCDgear to extract the dat file from the disk and re-burn it again.
I bought VCDs from different places on the net. I have no problem playing them. I recently bought two VCDs and they both have problem. I never burn any thing my self. I have extracted the dat file and following the procedure to reburn it new VCD. It may work
You should check via the DVD Compatibility list if you are using the correct media for your player - this could be the problem.
According to the list my DVD player supports all CD-Rs, but the question is how I suppose to know when I buy VCDs if it is burn on CDR or CDRW. My DVD player supports VCD,CD.
If you purchase VCD's they are or rather should be "pressed" not burnt CD's. If you have purchased VCD's that have been burnt, they are then pirated copies. If you have purchased them from a reputable website, store etc. and your DVD player does not play them, the store, website etc. will usually give you a replacement or refund.
Thanks for help everybody. I converted the DAT file to mpeg using VCDgear and reburned it back to VCD using my CDR. Works fine now.
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 19:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 05:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 12:20
