Whenever I encode an avi as an mpg2 for dvd, create a dvd menu for it in tmpgenc dvd author, and then burn the dvd video files with nero, the dvd video will become poppier and poppier in quality as the dvd gets to the end. So bad that in the last 5 minutes of the video, the dvd player will often times have to reset it's marker, causing the screen to go black until the video reappears and the dvd player has regained it's correct position. Before it gets to that point though, the DVD will occasionally have a frame or two of blocky video with an audio skip, and it will become a4 frames rather than one, then 3 block of nine frames in a row that will be ugly, until it reaches the point I described above. This also happened to dvd video files when I would use DVD Shrink to shrink them down to about 75% or less. The beginning would look great, but the end would be so choppy I could no watch it.
Are there any tricks to correcting this?
sounds like bad media. does it play ok on your computer?
After authoring save to a ISO image and burn with DVD decrypter, That's what I do. Good Luck
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
AutoGK encodes without sound
By eliserh in forum Newbie / General discussionsReplies: 14Last Post: 12th May 2010, 05:07 -
Question About Widescreen, I Think, Two Xvid Encodes
By hech54 in forum DVD RippingReplies: 5Last Post: 16th Sep 2008, 16:54 -
muxing VC-1 encodes to m2ts
By 02fx4dude in forum Authoring (Blu-ray)Replies: 5Last Post: 11th Mar 2008, 11:56 -
New PC - Encodes not as good...
By Browncoat in forum Newbie / General discussionsReplies: 28Last Post: 17th Jan 2008, 18:39 -
TMPGEnc encodes to 1%, then my PC restarts
By Syntax in forum ComputerReplies: 3Last Post: 5th Jul 2007, 17:18
