Hi,
I wanted to give DMS a try and I found out it works great with DVDM for still menus but not at all for motion menus.
Basically I got a background layer for the text and a sub-pic for the links (buttons). Problem is, I found out I can only use one sub-pic in DVDM so my menu looks very weird when I import my sub-pic over my motion background in DVDM.
According to DMS web site, you can create a motion menu by using a still from your motion menu as a reference. I did that as well but it didn't work. Am I doing something wrong? Did anyone else try to create a motion menu with DMS and DVDM?
Thanx for your help.
That's the only thing I can't figure out in DVDM: you can do awesome things, but concerning the menus, it seems like the motion background and the text layer have to be "rendered" together. Is there a relatively fast way to do that?
Pinnacle Studio - DVD menu with motion backround and thumbn.
By donpedro in forum User guidesReplies: 28Last Post: 28th Aug 2011, 12:51 -
DVD Menu bug in Pinnacle Studio 11
By P_Cherry in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2010, 09:22 -
Pinnacle Studio - Multilevel DVD Menu
By donpedro in forum User guidesReplies: 6Last Post: 5th Sep 2010, 09:16 -
Menu transitions/effects with Sony DVD Architect Studio
By sir_rob in forum Authoring (DVD)Replies: 9Last Post: 25th Jul 2008, 20:24 -
Vegas to DVD Lab Pro motion menu issues
By outerspacerace in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2008, 21:28
