How to fit 3 avi's converted to mpeg (1.5 hours each) in one DVD.
Thanx for any help.
MaCMeL
Results 1 to 9 of 9
Bless those people who help others without asking for anything.
Hello,
Use tmpgenc or another video encoder. Also, use this bitrate calculator to determine bitrates.
https://www.videohelp.com/tools?tool=3#commentsDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
There are at least three ways I can think of, 1 being the best way IMO:
1. Go back to the original AVIs and encode to MPEG-2 using TMPGEnc Plus or similar MPEG-2 encoder.
2. Author your MPEGs as is and use a transcoder like DVDShrink to make the output fit on 1 DVD.
3. Re-encode your current MPEGs.
The bitrate and rate control method is going to depend on the running time of all of the movies, whether or not you want a menu, and the quality of the AVIs to begin with, just to name a few.
You can work out the required bitrate using the bitrate calculator here.If in doubt, Google it. -
Hello,
Excellent point. One other option, if available, is to use the original source and rerip or recapture (if analogue) to get a better file size.jimmalenko-1. Go back to the original AVIs and encode to MPEG-2 using TMPGEnc Plus or similar MPEG-2 encoder.
Kevin
[/i]Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
No doubt your going to want to encode at 1/2 D1 Video which is 352x480 and use MPEG1L2 audio... maybe at <2k bitrate you may just get those all on one DVD.
I've never put 4.5 hours on a single (4.7Gb) DVD, but I have put about 3.5 hours on one, and at that level I got better results using standard resolution than the lower one. But my source material was low bitrate MPEG4 (~1Mbps), which probably influenced that outcome somewhat.
Hi everyone,
Thanx a lot for the reply. I wanted to add another question to DVD_Ripper, what do you mean by "encode at 1/2 D1 Video which is 352x480 and use MPEG1L2 audio". How can I achieve that. Before i posted my original question, I came across also abou 1/2 D1 during my search but does not understand it. Hope you can give me some more insight.
Thanx to u all,
MaCMeLBless those people who help others without asking for anything. -
Standard full resolution (D1) is 720x480 for NTSC. Half D1 is just cutting the horizontal by half. Still 480 vertical lines of resolution but you cut the horizontal (that gets stretched to fit on your TV display anyways) in half. This lets you get away using a significantly lower bitrate to encode to MPEG2 with. Think of it like this....say you have a gallon of paint. That gallon is your alloted bitrate. It's what you got to work with. You can either use that gallon of paint to cover a 10' x 20' area or you can only use it to cover just a 10' x 10' area. Which is going to look better?
Disclaimer: I have no ******* idea how much area a gallon of paint will actually cover.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
2 movies on one dvd
By hellbringer in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2009, 20:45 -
900min in 1 DVD? Several hours/DVD? Multiple movies or tv-series/DVD?
By edvashas in forum Video ConversionReplies: 17Last Post: 29th Sep 2009, 04:16 -
Getting movies onto a DVD
By rodeman in forum MacReplies: 3Last Post: 25th Jan 2009, 18:54 -
How many movies in a DVD?
By kkleo99 in forum Authoring (DVD)Replies: 2Last Post: 13th Feb 2008, 05:33 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 15:13
