hi
i don't know if this is the right place to ask but anyhow i was wondering if anyone experienced this before. i bought a canon elura65 on ebay knowing well that the camcorder i'm bidding on is not perfect. the seller did mentioned that there's no audio when you play it back on the camcorder. i got the camcorder and as mentioned, it's what's wrong with it. other than that, everything else works fine, including audio when played on tv. i'm planning on sending the dvcam to canon to get it fixed. how big of a problem is this and do you think the canon people will mess with it? btw, included with the cam is the whole kit that came with it when he bought it, including the warranty card.
What do you mean - will the canon people mess with it. If you send it in to be serviced by Canon, it will probably be serviced. Will the do it under warranty ? No reason not to unless the existing warranty required registration and only applies to the original purchaser.
If the problem was not serious though, why didn't the original owner get it fixed under warranty ? -
"If the problem was not serious though, why didn't the original owner get it fixed under warranty ?"
i really don't know. i could only guess. even if it was serious, and it's under warranty, it would still be covered.
i'm just wondering if anyone has this type of problem before with elura 65, and what was the outcome of it...[/i]
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 11:39 -
Help With Audio Problem please!
By heidilynn08 in forum AudioReplies: 3Last Post: 16th Dec 2010, 12:08 -
audio problem
By harariman in forum AudioReplies: 10Last Post: 7th Jan 2009, 22:31
