Now, I have lots of my favourite resources such as flash, powerpoint files and pictures, all of these from my heart I want to make a gift to my best friend, but she doesn't like computer at all, and even can't use it, she is just so naive, I just don't know how can I present all of these viewable to her? Because she like TV so much, I think it would be better if I can burn all the presentations onto a DVD, then she can view them on regular TV set. But, can those presentations be burnt to DVD format and also play normally?
Need ur help, and TIA.
WARNING SPAMMER - DON'T BUY THIS PRODUCT
/ Moderator Offline
convert everything to mpeg and author the images as a slideshow.
flash converters
swf2avi
SWF2Video
WinAVI Video Converter
Magic Swf2Avi
or use a screen capture utility like camstudio
powerpoint
PowerPoint2DVD (you can create a dvd and then import the vobs when you remake the dvd)
author
with for example dvd-lab, it has a built-in slideshow creator. -
While the answer isn't an emphatic no, it can't be done without a lot of work. There are a variety of tools available that claim to convert powerpoint or flash to avi. I have yet to find one that
a. does all of them
b. works where there is interaction required - I have not seen anything that could take an interactive flash presentation and change it to a DVD, preserving functionality within the DVD menus.
c. Produces good results every time
assuming you could find the correct programs to convert each these, you would then have to produce a series of clips (one for each presentation), edit them together, encode as DVD compliant, and build a DVD. You could add an extra folder in the root of the disk to hold the original versions of each presentation so others with more PC skills could access them.
So yes, with a lot of work you could get them into a format viewable on a TV. With even more work you might be able to recreate some of the interactivity of the originals. It would probably be quicker to teach your friend the basics of owning a PC though. -
Hello,
If you wanted the realtime approach you could (if you have a tv output) copy them to video tape. Just hook up the computer to a vcr and play your presentations at full screen (then record on vcr-have the sound card attached for sound presentations). You won't have fancy menus but if you want to keep it simple that would be a way to do it.
Kevin
(also - it won't be able to be manipulated- just a straight play through)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I have good suggestions to you as below:
about Flash: FlashOnTV http://www.flash-on-tv.com
about PowerPoint: PowerPoint2DVD http://www.powerpoint-to-dvd.com
about Pictures: Photo2VCD http://www.photo2vcd.com
Photo2DVD http://www.photo-to-dvd.com
You can try these, hope help! -
i have a question about powerpoint2dvd. i have been using a screen capture program (snagit) to convert a self timed powerpoint to avi but sometimes the results for the animations are a little pixelated. how close does the result of powerpoint2dvd resemble the original presentation? also, the website mentions something called mini dvd. is that just another term for vcd?
thanks a bunch.
bmac_007 -
Hello,
Minidvd is a vob on a cdr (dvd video on cd). It has limited compatibility and it has less storage capacity then vcd for a cdr.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Capturing clips from DVD's to embed in PowerPoint presentations?
By billy_ball2 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Aug 2013, 11:27 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35 -
Feedback on software for converting Powerpoint Presentations to Video
By LJB in forum Newbie / General discussionsReplies: 3Last Post: 5th Jun 2009, 08:21 -
Looking for a presentations program to make dvd menus
By faramith in forum ComputerReplies: 0Last Post: 1st Jul 2007, 10:00
