I use ulead vs7. I can transfer dv from my sony into the program as dv,
or mpeg amd some others. Iam wondering if it is better to transfer as a dv(avi) or straight in as mpeg. thanks
If you intend to edit or adjust it in any way (add titles, colour correct etc) then transfer as DV. What you will get on the disk is bit for bit what you recorded to tape. Once you have finished editing, export it as DVD compliant mpeg.
If, on the other hand, you just want to burn it to disc, you could just capture it as mpeg. If you do this, make sure you use a high bit rate CBR, as multi-pass VBR probably wont be available to you during the capture process.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
