So I send some DV files from my Sony CAM into the Computer using PowerDirector...Unfortunately, I converter them into MPEG-2 format and after adding all the titles and effects...I'm ready to put them into a DVDr...but when I got to PRODUCE my (about 1hr15min long) movie, the process estimated to take about 6 hours....Is this For real...I mean...All the files are MPEG2 already so there shouldn't be any long encoding....I did add some special Effects but none that would take that long....
Since i'm new to PowerDirector, I'm not sure if this is some kind of mistake or if it's how the software works....
Do any of you guys out there have any solution for me??...I wouldn't mind using another software but i like to be able to put on some titles and Effects onto my movie....
Suggest you fill in your profile. It may be that your computer is too slloooowwww. Anyhow, filling it in will certainly help others on any future posts.
Okay...SO I kinda figure out my problems....Yes, My computer is a little slow but that's not my problem....When I first created the MPEG-2 files, the resolution is in 640x480 i think.....But a DVD requires it to be 720x480....Without knowing this, I try to created a DVD file so PowerDirector end up RE-ecoding the whole clip from 640x480 to 720x480....that's why it takes so long....Now that I know, I just need to keep everything simple....Thanks for the reply tho.....
I'm thinking about maybe giving Adobe Premier a Try....who've tried both give me a little of what Premier CAN and CAN'T do comparing to powerDirector??
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 15:22 -
PowerDirector: Extract single scenes from Movie --> HUGE(!) file
By Katzwinkel in forum EditingReplies: 1Last Post: 5th Nov 2010, 16:46 -
Ripbot Not Producing Locked File Size
By Rustsatz in forum Video ConversionReplies: 0Last Post: 15th Jan 2010, 09:40 -
about saving file in cyberlink powerdirector
By admirer in forum EditingReplies: 3Last Post: 15th Apr 2009, 10:30
