  1. Is there a way to add a .vob file to an existing DVD movie? I have created a DVD movie and I want to add an intro to it from a seperate movie which consists of a vob file. I heard there was a way to do it using ReJig, but not sure how. Thanks!
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    There are a couple of ways. First, take a look at tmpgenc dvd author. It will let you import dvd vob files. You could load your original project first and then add the extra vob. Second, I'm not an expert with it but try ifoedit. I believe this will also work. Third, I think dvd-lab is an all in one dvd authoring progam- though I haven't used it myself.
    Kevin
  3. cool thank you very much, I will explore all possibilities. I have tmpgenc dvd author, maybe now is a good time to learn how to uise it
