Hey all.
I just purchased a external dvd burner for my laptop. It is a MadDog usb 2.0 version. I do know that its a rebatch of the NEC ND-2510A 8x burner.
WHat I am trying to do is back up one of my Asian R3 dvds to a dvdR. But for some off reason, I guess it will not burn a R3 dvd maybe b/c my burner is not regionless or region free.
By anychance is there any thing I can do so that I can start backing up my R3 dvd movies? Software to download or anythng? Thanks all 4 your help(S).
-Regal
*New Mac user*, been PC user 4 life
I have the internal NEC ND-2510A 8x burner. I use AnyDVD to make my
burner region free. Works great. -
Use REGION KILLER which is a free software to use. Here is the download for it: http://www.digital-digest.com/dvd/downloads/dvdrk.html
Use Mirror 3 to download REGION KILLER.
The DVD external burner you have needs to be REGION FREE in order for you to back up your region 3 dvds. Here's the firmware index website where you can download the region free firmware for your rebadged NEC drive that is created by the DANGEROUS BROTHERS.
http://forum.firmware-flash.com/dl_firmware.php?category=4&manufactor=23
mrsoul1952 wrote:Why pay for AnyDVD when REGION KILLER is a freeware tool!!!!!I use AnyDVD to make my
Rock on!!!
Thanks all.
BTw, this was weird. but when I put in my original R3 dvd into my laptop dvd player (not my external burner) and then run Shrink it did its job.
But on the 2nd R3 dvd, it would not do it or a menu screen came up saying I can change the region only 4 times and it would be locked or something like that. lol.
Oh well.
But I will try these 2 softwares. Thanks guys!!*New Mac user*, been PC user 4 life
New to DVD movie burning - Help?
By dvdburning in forum Newbie / General discussionsReplies: 3Last Post: 11th Jan 2010, 00:51 -
Burning a movie to DVD
By johnnyo34 in forum Authoring (DVD)Replies: 6Last Post: 6th Jan 2010, 19:04 -
Dumb Question - Burning Blu-Ray movie with a standard DVD-R burner?
By toxicquack in forum Authoring (Blu-ray)Replies: 7Last Post: 18th Aug 2009, 04:59 -
Burning DVD movie into CD R
By c1steady in forum Newbie / General discussionsReplies: 17Last Post: 8th May 2008, 15:17 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 19:41
