I have a 450 mhz PII. I need to know the fastest way (short of getting a new computer. Has to be this one!
) to get video off of a DVD onto the hard drive in a format that I can use later on with TMPGEnc! DVD X COPY takes waaaayyyy too long because it involves burning a DVD. Any tips, tricks greatly appreciated! Thanx!!!
"If it were easy then it wouldn't be a shortcut, it would be the WAY."
I would go for a 2 step process;
1) DVD Decrypter to rip the material to the hard drive, and
2) Auto Gordian Knot to convert to an avi.
Tom -
Hello,
You could look for a capture card that will run on your computer. That way you'll have it in realtime (and one that will remove macrovision- assuming of course you have a standalone dvd player).
You'll lose 5.1 sound however (unless you have a soundcard with a digital input)
Originally Posted by HonkyTonkBlues13
If this is the case, the first step is to rip the DVD to your Hard Drive. I would use either DVDDecrypter and the guide here or SmartRipper and the guide here.
You have a number of options for the next step. You can feed the files off you Hard Drive into DVD2AVI, which will create a .D2V file and your audio file. You can then load this .D2V file directly into TMPGEnc with your audio.
What do you want to end up with in the finish ?If in doubt, Google it.
MTS to AVI on slow computer
By Mort126 in forum Video ConversionReplies: 1Last Post: 29th Jun 2010, 15:01 -
Dvd rip(HD) in mac - Mov,mpg,avi
By nimrodm in forum MacReplies: 3Last Post: 9th Feb 2010, 07:33 -
MPG to h264 w/ATi TransCode Converter 1.01b, audio just won't encode *argh*
By ultradouche in forum Newbie / General discussionsReplies: 2Last Post: 26th Nov 2007, 09:33 -
Playback video too bright in mov, mpg, avi, wmv, etc in all players
By PhilippZ in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2007, 15:02 -
DVD Decrypter awful slow on new computer
By zainka in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2007, 11:24
