Hello,
I am currently using Winfast PVR that came with my TV tuner and I am wondering if there is a better alternative out there for TV viewing. DScaler was great until it didn't work one day.
Winfast PVR is horrible because the deinterlacing causes artifacts and horizontal lines to randomly appear when there is movement.
Here is an example of the lines captured with Winfast PVR.
http://ucsu.colorado.edu/~auyeung/a.avi
Does anyone else have this same problem when using this card?
Thanks!
I looked at your sample and didn't see any interlace artifacts. What I saw was severe macroblocking caused by too low a bitrate for the high motion video. You need to bump the bitrate up.
Keep in mind that when Divx is capturing in real time it doesn't have time to do a full analysis of the video to get the best compression. So you'll need a higher bitrate than you would with a two pass encode. Your sample was at 1200 kbps. I'm guessing you'll need to double or triple that.
What size of tv are you watching?
By johns0 in forum PollsReplies: 25Last Post: 4th Feb 2012, 01:17 -
Lag when watching HD
By jester5120 in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 18:43 -
watching video from pc to tv
By butterflies in forum Media Center PC / MediaCentersReplies: 1Last Post: 10th Jan 2010, 10:51 -
watching TV on your PC
By coteauhills in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2008, 15:50 -
what are you watching?
By pantsonfire in forum Off topicReplies: 7Last Post: 19th Nov 2007, 15:28
