When I multiplex using bbMpeg, i keep getting buffer underflow errors. Tried increasing mux rate, but that seemed to make it worse. any ideas as to what i can do? tried TMPGEnc, but similar happened.
what type of file are you trying to multiplex?
If it's an SVCD, make sure those are checked, set muxrate to 0 (auto). This makes BB find the bitrate itself, and flags/multiplexes it accordingly. -
The video and udio streams were originally exported from Adobe Premiere 6.0 with bbMpeg using Mpeg-2 streams. used all the default values, except lowered audio to 128 kb/s
How do I multiplex to FLV?
By Videogamer555 in forum Video ConversionReplies: 5Last Post: 30th Aug 2011, 03:26 -
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45 -
Problems with BD Rebuilder: failed attempt to multiplex
By ajhansen91 in forum Blu-ray RippingReplies: 6Last Post: 23rd Apr 2009, 10:06 -
demultiplex and multiplex ..........HELP!
By efiste2 in forum DVD RippingReplies: 1Last Post: 21st Jul 2007, 17:01
