Currently doing a large amount of capturing of home video to my PC.
I am running Win XP Pro with 512mb ram.
Would I notice any difference by sticking another 512mb in it or is it a waste.
Opinions please
Kwack
If it's capturing fine now, no. DV capture over firewire happens at a fixed rate no matter what you do. A more powerful system won't enhance anything.
You should be just fine with 512 mb ram. I'm running an AMD XP1700 w/768 mb ram. I usually run Premiere Pro and Photoshop (big memory hogs) at the same time. I never run into problems, even when I use to run 512 mb ram.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I think it is fair to say that it is generally accepted that 512MB RAM is about all you need with Windows XP, and that 1024MB would be slightly better, but not absolutely necessary. As a few people have mentioned, if you're getting the results now then there's probably no need to change anything.
That said, I had a P4 3.06B running with 512MB RAM on a cheap Shuttle board. I bought myself a new mobo and another 512MB RAM and noticed a massive difference when I configured hyperthreading and put my RAM in Dual Channel mode. The difference only comes in the encoding stage (which is generally the most time intensive stage). For 2-Pass VBR using TMPGEnc Plus I went from encoding times of 3-4X runtime (2 hour movie takes 6-8 hours to encode) to 1.3-1.5X runtime (2 hour movie now takes 2½-3 hours to encode).
I would call that massive
Like all good weight-loss ads, individual results may varyIf in doubt, Google it.
PC memory
By alintatoc in forum ComputerReplies: 17Last Post: 17th Nov 2009, 17:24 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Memory
By ProducerHarley in forum ComputerReplies: 1Last Post: 3rd Dec 2008, 00:38 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
