Hi peeps, Ive extracted a MPG file out of a SVCD Bin file and all i really want to do is convert the MPG file into AVI that Toast 6 with Jam will happily encode and burn......
The file im trying to convert is this:
VIDEO: mpeg-2, size: 480x576, 25.000 fps, 2556 kbps. AUDIO: mp2, 44100Hz, 224 kbps.
When ever i drop it onto Toast and try and encode and burn as a DVD it errors in Toast. The MPG file plays ok in Quicktime. Ive tried to use one of the AVI settings in FFmpeg but the AVI file i got didnt have any sound in it...any help would be appreciated. cheers. PS: i dont have a registered copy of FFMPEG so not all the features work!
Results 1 to 23 of 23
If you're going to transcode, why not directly to DVD in ffmpegX? Two encodings will result in extra quality loss. Also, Toast’s DVD encoder has very little quality control.
No idea about your audio loss, though.
Okay, here's a little just-tested how-to.
Open: Open your SVCD file or folder in ffmpegX. Save as: Set output location and filename. I prefer a new folder in root for easily finding my files again. From the Quick Presets, choose 'fast DVD'. Hit encode and wait. After ffmpegX is finished, a new folder with a name ending in '.DVD' is in your output location. Rename that new folder to what you like the DVD disc title to be, within naming specs. Drop on Toast in UDF mode. Record.
This is re-encoding to 720x576, not SVCD-on-DVD, so it takes some time. My 50 second test clip took 4:12 processing time, or roughly 5 times as much as the duration of the movie. So I expect a full movie could easily take 8 hours+ on my machine.
Ah yes ive updated FFmpeg and thats done the trick, thanks, it is now encoding so I will post my findings when it is complete....thanks again.
Case, its happily encoding one of the MPEGs i extracted from the SVCD but when i hit the preview button in FFMPEG it plays the movie but with no sound??? is this correct?
I seem to remember encoding the same file as a AVI before using FFMPEG and it had no sound at the end of the encoding also..
Did the ffmpegX Progress window say it was finished, with the 'ping' sound? There should be a log with useful information if you press the blue (i) in the Progress window.
Or try a new encoding of just the audio, using "Movie audio to ac3" preset. Should only take about 7% of the time compared to the video. If somehow there are no errors this time, you should be able to combine the video from earlier with the new AC3 file. If there are errors, report the log.
Encoding started on Thu Aug 5 00:11:32 BST 2004
audio channel = 1, 18900 Hz, 2 channels, 8 bits/sample 0
Input #0, psxstr, from '/Users/ben/Desktop/Downloads/movies/movie1.mpg':
Duration: N/A, bitrate: N/A
Stream #0.0: Audio: adpcm_xa, 18900 Hz, stereo
Could not find input stream #0.1
Doesn't look like mp2, 44100 Hz, stereo, 224 kb/s or ac3, 48000 Hz, 5:1, 448 kb/s at all!Originally Posted by smuudge
To Major: I'm out of my league here, maybe you can tell what's going wrong here.
For comparison, my 'Movie audio to ac3' log is:
Encoding started on Thu Aug 5 08:13:00 CEST 2004
Input #0, mpeg, from '/Source/Movie.SVCD.CD1.mpg':
Duration: 00:51:59.6, bitrate: 2083 kb/s
Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps
Stream #0.1: Audio: mp2, 44100 Hz, stereo, 224 kb/s
Output #0, ac3, to '/Output/audio_1.ac3':
Stream #0.0: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream mapping:
Stream #0.1 -> #0.0
video:0kB audio:170664kB global headers:0kB muxing overhead 0.000000%
bench: utime=760.920s
Encoding completed on Thu Aug 5 08:26:14 CEST 2004
im wondering if the mpegs i have are abit corrupt? They have been ripped cleanly out of a SVCD bin file and play perfectly on the Mac........seems strange that when i ever encode using ffmpeg the resulting files are empty of audio..
ive finally given up on this, no joy with ffmpeg and toast is still refusing to burn the files. If anyones got any bright ideas im all ears! If not the files are going in the bin! THanks for all the help anyway.
Burning AVI Files in Toast 7
By Luckyword in forum MacReplies: 9Last Post: 16th Jul 2010, 13:05 -
movie to mpg for dvd by toast too large; "keep in" been ignored
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 14:26 -
avi to dvd in toast 9
By levi747 in forum MacReplies: 4Last Post: 2nd May 2008, 22:43 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08 -
AVI file to DVD using Toast 8.0
By Huntr777 in forum MacReplies: 7Last Post: 29th Jun 2007, 09:24
