Hi,
Can someone please help I have used WinAvi (v5.7) to capture and convert a .avi file to DVD, however I have converted it Ok and it has saved a folder called DISK_0 on the hard drive.
This folder has AUDIO_TS & VIDEO_TS folders in them however when I burn them to a disk and put it in a standalone DVD player it comes up NO PLAY, WRONG DISK etc even though the files are in DVD format?
Please does anyone know how to burn these?
i had problems like that with 5.07.279 or some version like that.
it would convert fine and burn with copytodvd,or nero,and it wouldnt work.
and i know it was right,no files in the wrong place,etc.
in the end,i went back to beta2 of 5.7 and it works ok,just that they should get that green bar crap at the bottom of some files fixed.i get it more often than not.
how to burn more than one movie to DvD using Winavi?
By apachie in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2009, 23:40 -
WinAvi DvD Problem
By AHS789 in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2008, 18:05 -
WinAvi DvD Problem
By AHS789 in forum Authoring (DVD)Replies: 0Last Post: 15th Nov 2008, 01:58 -
WinAvi DvD Problem
By AHS789 in forum Video ConversionReplies: 0Last Post: 15th Nov 2008, 01:57
