Results 1 to 9 of 9
  1. I remember everyone talking about this great screenshot utility for apple. Does anyone remember what the name of this program is? or a comporable version used for PC if no one can remember that one? Thanks guys-
    "What's a matter Colonel Sanders???? CHICKEN???!!!!
    Jun 2001
    Silver Spring, MD USA
    You can take screenshots from key combinations (in OS X).
    Apple+Shift+3 will capture the entire desktop
    Apple+Shift+4 will allow you to draw a section of screen you want captured
    Apple+Shift+4+Spacebar will allow you to capture any window
    All captures are saved as PDF files associated with Preview. I use Adobe Photoshop to convert these PDFs to JPEG.
  3. You are the man- Thank you so much for your help!
  4. I use Capture Me.. It's freeware, works great and can even capture DVD screenshots..
    Jun 2001
    Thats right ... The Apple method will not let you capture any MPEG2 frames, encrypted or not. The captured window or area will just be black.
  6. Member terryj's Avatar
    N35°25.24068, W097°34.204
    second vote for Capture Me...in fact, I think
    I mentioned this a couple months earlier...?
  7. Thanks guys! I'm gonna give it a shot tonight when I get back to my apple!
    Feb 2003
    Calgary, AB Canada
    add the 'control' key to any of these key combos, and the screenshot will be on your clipboard intsead of creating a file.
    then you can paste it in photoshop. Its great when you need more than one screenshot in one photoshop file.
    --sdm
  9. Everything worked out great! Thanks everyone! -
