I burned a VCD using Windows Media Player to play it. I wanted it to autorun (i did it) and play continuously. Looking at the WMP command lines, I found no one that enabled that feature to be set previously. Is there any way to do it? What I am doing is printing some instructions explaining how my client can set WMP to do it by himself.
Thanks for any help on that.
Andre Senra
Why dont use use ASX file?
and at your autorun file something like:
[autorun]
open=mplayer2.exe /play vcd_playlist.asx
Look at web for some ASX sample -
Does it make a difference, whether my file is a MPEG-1 file or an ASX? I, for one, prefer to use the former due to the better quality. And since WMP plays MPEGs as well...
Perhaps I shouldn´t use the /close command line. Now you mentioned that, I remebered I included it. Yet I wonder if it will keep on playing continuously or just stop by the end of the clip. -
ASX is a playlist file, you can put information about MPEG clip, and it will play continuous (like a playlist)
------------ cut --------------
<ASX Version = "3.0">
<title>My playlist for VCD play</title>
<author>VingadoR</author>
<entry>
<title>Clip title</title>
<author>Clip author</author>
<copyright>©2001</copyright>
<Ref href = "filename.mpg" />
</entry>
------------ end --------------
i'm forgot, when you finish to put
<entry></entry> tags... finish file with </asx>
How to Use x264 Command Line
By Anonymous344 in forum Newbie / General discussionsReplies: 37Last Post: 2nd Nov 2013, 08:49 -
avidemux2 command line help
By Choller in forum EditingReplies: 0Last Post: 31st Dec 2009, 05:17 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
A-B repeat in command line
By alexandre_fs in forum Software PlayingReplies: 4Last Post: 15th Jan 2009, 15:35 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 1st Jun 2008, 23:44
