I've accidently bought a used dvd from a store and when I got it home I realized it was Pal(Only one there so can't take it back to get another one)
Anyways I used DVD Decrypter, than Tmpgenc 3.0 Xpress. When I go to play the file to make sure everything is ok there is no sound. Is there another program that could help get the sound?? Thank you for any advice given.
I did a succesful PAL to NTSC conversion after ripping to the HD using Nero Vision Express. Usually NVE is a pain because it transcodes everything, but in this case it was neccessary. Took 6 hours to render on my lowly 1.4 GHz PC, and I had to reathor the menus as well, but it worked on my standalone at the end of the (next) day.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Sound popping after converting PAL AVI to NTSC DVD using DVDFlick
By embreeb in forum Video ConversionReplies: 3Last Post: 25th Sep 2007, 10:46
