Results 1 to 28 of 28
  1. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    WTF ???
    If in doubt, Google it.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Rules for a successful post:
    1) A topic that makes sense
    2) A question that makes sense
    3) Details in first post.
    I don't see any of these here :P
  3. Member Treebeard's Avatar
    Aug 2002
    Conditions needed to flame somebody.
    1) short choppy illiterate typing
    2) a post that makes no sense at all
    3) A few OT people floating in the regular forums to start the flames.
    start flaming Or you could edit this and turn it into a proper post.
  4. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    You'll have to excuse my friends...they can be rude sometimes.
    What they are trying to say is:
    You seem to be having cranial-rectal inversion and before you can download or record from this website you will need to see a doctor about you current condition.
    You also seem to have another issue that lies somewhere between your desk and your chair...I'm not exactly sure what you can do about that but lets try huh.
  5. Anonymous
    Guest
    try camstudio.
  6. Good luck.
  7. Master of Time & Space Capmaster's Avatar
    Feb 2004
    At least he didn't do what that one noob did here a few months ago - posted his e-mail address and said "e-mail me and I will describe the problem for you". Even I got in on the flaming with that one
  8. Banned
    Jan 2004
    Going in Circles
    He could have looked in the dictionary to learn how to spell the word site.
    Nah, that would be too hard for him.
  9. Assuming you want to record streaming audio from that site, then this will probably work:
    http://www.highcriteria.com/
    If you're trying to do something else, then you'll have to be more specific. There's a lot of smart people around here, but none are mindreaders that I'm aware of.
    Good luck.
  10. wow.
    ok.
    i have worked with this a bit.
    if you want to capture streaming audio from the web just bring up your windows mixer and select wave or sum as the record channel. select the same one in any audio recorder (i like Sound forge) hit record a few secs before the stream starts.
    if its video, the camstudio will allow you to record a portion of your desktop
    check to see if its flash. you can "download" flash animations with a proggie called flashcatcher, then turn it into an avi with procoder
    if its both video and audio like a band's new single, you can avoid problems by doing them separate then mux them later.
  11. hi
    i want record video only
    CamStudio recording black screen
    help me
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by marcoja
    hi
    help me
    Originally Posted by Supreme2k
    OK. marcoja, I really think you need to tell us exactly what it is you wish to do in about 50 words.
  13. http://babelfish.altavista.com
    Looks like English isn't your first language - this should help you translate what you really want to say.
  14. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  15. A registration was wanted rabid presented in this http://www.wmrecorder.com/index.php
    The programs register but the picture is black
    He felt sorry that we are from arabic
    thanks for all
  16. Video Restorer lordsmurf's Avatar
    thanks for all
    That's about what my Chinese looks like when I use a translator. Barely makes sense.
    From what I gather, he cannot get it to work.
  17. i've had fairly good results with this translator
    http://www.web-a-dex.com/translate.htm
  18. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    OMG! these are the tools i've been looking for...thanks a lot for those who gave the Name of the tools
    Dr. Gee thanks, anubis13 thanks...i hope other guyz could be as helpful and direct as you two
    hacking the Net using typewriter :D
  19. no recording
    thanks pchan
  20. Member pchan's Avatar
    Mar 2003
    Singapore
    Here is the steps you must do in order to capture audio and video stream to an AVI file.
    1. Launch Snagit
    2. Goto Tool and select Video capture
    3. Goto Input and check Record Audio
    4. Goto your browser and start the streaming
    5. Hit the red capture button and use your mouse to select video display
    6. The Snagit window will pop and press start.
    7. The red camera icon will be flashing on your task bar. Double click it to stop recording.
  21. sorry pchan
    recording is black screen
  22. I think that it is time to give up.
  23. Member
    Feb 2002
    Under The Sun
    Hi. I just succesfully captured a flash intro from a website to test with Snagit - only thing was no microphone plugged in for sound, was a little slow but maybe thats my PIII 1gb Chip.
    Nice tool.
    Thx.
    TheEverLiving
    "Smell The Flowers Whilst You Can."
  24. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    thanks pchan...ill try also Snagit
    any other good program out there?
  25. Member
    Dec 2002
    Cary, NC, USA
    no recording
    thanks pchan
    If this means that you're seeing the video, but the program you're using only records a blank, then try this:
    Open Windows Media Player, then Tools menu then options. Performance tab, then advanced. Read through the options and turn off 'Use overlays'. Most programs will not record overlays, forcing them off will often let you cap the video.
    Of course huge assumption that you've made it this far and this is what's happening but overlays are a problem for many programs.
    Alan
