i have an USB webcam Kodak ez200
is it possible to create VCD by capture webcam video?
its specification
30fps@cif 352x288
26fps@vga w/ 500mhz system
15fps@vga w/ 266mhz system
However, i dont know why, it comes out that the maximum rate i can capture video is just about 15fps
its not smooth enough for vcd
my hardware configuration
amd athlon xp 1800 +
768MB ram
60GB 7200rpm harddisk
windows xp
If webcam is able to create vcd
will it help if i buy another webcam?
or its the problem of my hardware configuration?
You should put your hardware configuration into your computer profile. Will help for future questions.
In general, you can turn a webcam video into VCD if you want. The framerate can be converted to a VCD compatible format. Yes, it may be a litttle jerky. If your webcam is using USB 1, the framerate will be slow.
You also didn't say what format the webcam is outputting. Makes a difference. I run similar videos through VirtualdubMod and the output with frame conversion is watchable.
Expirement a little. Most of the software in the 'Tools" area to the left are freeware or trialware.
A good software to capture and record video from webcam.
By prankstare in forum Video Streaming DownloadingReplies: 10Last Post: 12th Dec 2018, 21:40 -
What's the best way to capture someone speaking from their webcam?
By chrisj in forum Newbie / General discussionsReplies: 25Last Post: 7th Jun 2011, 11:44 -
C-it WebCam Capture (Xirlink) Video Conversion
By PalPart in forum Newbie / General discussionsReplies: 0Last Post: 10th Aug 2008, 11:08 -
Best Webcam Capture Program
By Rowan88 in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 08:02 -
How to create a forum that allow to record webcam and post video messages?
By deafeagle in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2007, 13:03
