  1. Hi, I COnverted A Movie Successfully And I Tried All The VOB files Out And THey WEre Goodd All Worked Perfectly.
    I Burned Using NERO 6 And When I Play It On A DVD Player It Fucks Up On The Same Part....Which DVD Burner Is Better Than Nero? Thanks
  2. Member jetfan's Avatar
    Mar 2003
    new york
    Nero's only a program, are you using the right settings? I personally
    use copy to dvd and never have any problems.
    Also, when you say that you converted a movie successfully, does that
    mean that you used a program to shrink it to fit on a dvdr or was
    your movie already under 4.7 gig?
  3. the movie file was 2gb and i increased it 2 4gb so i wont waste disks
  4. Member jetfan's Avatar
    Mar 2003
    new york
    the movie file was 2gb and i increased it 2 4gb so i wont waste disks[quote]
    I don't understand what you mean by this, what exactly did you do?
