I have obtained a dvd recording that has a very important program on it, but the picture is very noisy.
So.........., I am putting the dvd player through my advc300 and getting a much better picture using the filters, but guess what!!, the audio is out of synch even though the advc has audio locked!
Help!!!
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
You'd probably have better success by ripping the DVD to your computer, demuxing the VOB and running the MPEG2 video through some kind of filters.
You might even need to go as far as converting it to AVI and working with it from there.
After you get the video the way you want it, re-author with all the pieces and hopefully al will go well. -
hey thanks, have fixed the problem, just needed to restart the picture controller software, as usual though more questions!
I have removed the fuzzy, but am getting a sort of "Looking through plastic wrap look" sort of shimmery, I think thats over doing the sharpness adjustment?, any ideas-big thanks.
TPAL/NTSC problem solver.
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
Fixing bad resampled DVD audio
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 11:59 -
Camtesia 6 recording for YouTube bad quality
By isabelleve in forum Video Streaming DownloadingReplies: 1Last Post: 5th Mar 2009, 15:58 -
Fixing bad tracking
By J C in forum RestorationReplies: 11Last Post: 7th Sep 2007, 08:11 -
Fixing bad PAL->NTSC conversion
By Goldmonkey2828 in forum Video ConversionReplies: 1Last Post: 30th Aug 2007, 20:40
