I am able to complete all the steps until it is time to output the dvd into the burnable folders. When I click "begin output," the program crashes. It just disappears.. Any ideas how I should fix this problem?
probably going to need a little more info.
System specs
Are you reading and writing to the same HD
File size
etc, etc.
Also try writing to an ISO rather than folders. You can still burn it with DVD Decrypter. -
This particular program can do things like this if the files aren't really right, in other words if the files are corrupted or start off ok and have problems further in. You will usually see this when it is generating the menus as it needs to create the thumbnails for the chapters.
Things to do if it is more than one file try them one at a time and see if you can pin it down. I have had times when an encode I did with TMPgenc Plus will be wonky. usually from a bad source file that didn't crash it but did cause problems.
Good Luck
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 23:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
