I downloaded firmware for nec 2500a but it wouldn't let me open the file and it asked me to open it with another program. What program do I open it with? Thanks.
Angie
firmware must be installed a certain way or it won't work. there should be instructions on the website you got the update from, or a readme file or something like that. the best idea would be to follow the instructions provided to the detail.
how do i install/upgrade firmware using usb stick? dvp5992?
By mike69 in forum Newbie / General discussionsReplies: 14Last Post: 29th Jan 2012, 01:05 -
will not install
By ka3wjz in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 30th Jun 2009, 22:07 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
should I install LG GSA-H55N firmware update 1.02 (July 2007)?
By JohnnyBob in forum DVD & Blu-ray WritersReplies: 3Last Post: 18th Aug 2007, 00:12 -
Use without an install
By raschko in forum Newbie / General discussionsReplies: 0Last Post: 9th Aug 2007, 17:37
