Dear All, I have a video file that "claims" to be a SVCD movie. However when I try to burn it to a CD Nero gives me a warning that the audio is 48.000 Khz instead of the standard 44.1 Khz, can this be changed without recoding the whole movie. Also if I try to watch the movie on my PC with either Windows media player or DivX player the movie plays but the aspect ratio is all screwed up, it is severely squeezed from the sides and the audio is out of sync. Can these problems be fixed? Thanks in advance! Lars
First, go download Zoomplayer and try that. It should fix your aspect ratio problems (you can adjust the AR to whatever you like). If your audio sync problems persist you may need to adjust the sample rate. To do that search the guides for "demux" or "resample audio".
Yes, you can adjust the audio without having to touch the video stream. There are different ways of doing it, but it depends on how the audio is screwed up (48khz vs 44.1 by itself should not cause sync issues when played back with something like Zoomplayer, so it could be a different problem)
-Suntan -
Dear Suntan, That did the trick! Thanks a million!
Best regards
Lars
Fixing aspect ratio?
By hiimbored in forum DVD RippingReplies: 16Last Post: 9th May 2008, 14:40 -
Fixing wrong aspect ratio.
By mattstan in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 15:17 -
fixing aspect ratio
By wayshway in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2008, 11:21 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 02:09 -
how to rip audio from DVD and AVI without re-sampling
By ted demen in forum AudioReplies: 9Last Post: 23rd May 2007, 11:23
