Results 1 to 9 of 9
    Jun 2004
    Misissauga Ontario
    Hi, Im new here. I just bought a new DVD Burner. No I need to know a few things. Whats the best software? is Nero 6 good? because its on sale at Best Buy. Also I need to know how you would turn MKV miles to DVD. Thanks
  2. Start reading!!
    The column on the left has lots of good information.
    USA
    As above, and:
    1. Whichever software works best for what you want to do.
    2. Nero is useful for some things, Not so good for others.
    3. For MKV, Start here. http://www.matroska.org/
    Jun 2004
    Misissauga Ontario
    um...ok ill start reading. My family went on a trip last year and we recorded alot. I used Movie Maker and turned it into 2 seperate parts with subtitles and other stuff. THen i used tmpegnc to encode to mpg. I just bought Nero and I have to say that it was a waste. they dont let you create dvds, but MINIdvds. I heard that first you have to author, then compile. Is DVD Lab good from that?
  5. if you done it right with tmpgenc yes dvd lab will convert/add 2 ,3 movies together and spit them out as vob files so you can burn them with nero or watever
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Keep reading....
    If you are only getting the option for a miniDVD then you have to make sure you have the DVD part selected and not the CD part. I always recommend noobs use Nero Express and the guide here, as I think it is a bit easier to learn than the standard Nero interface.
    If you have used TMPGEnc Plus to encode to MPEG-2, then you need to author. I would suggest TMPGEnc DVD Author.
    If in doubt, Google it.
    Jun 2004
    Misissauga Ontario
    I just found the all in one Ulead Video Studio . its amazing. Im backing up a dvd right now, but .....it takes A LONG time to convert the video
  8. Best of luck...
    Ulead makes some very user friendly software ... Video Studio 8 and DVD Movie Factory.
    Yes... the slowest operation will be converting your AVI ro MPG for DVD burning..... what is your machine specs?
    Jun 2004
    Misissauga Ontario
    2.5 ghz. 512 mb ram. 120 gb. Still....its going slow lol. Pretty awesome though.
