I do have a DTS file which is encoded 768 kbps already and I like to encode it to 448 kbps, is there any tool out there to do this? any guid?
thanks
you should not do this -- as it will either ruin the file or not play or maybe not even be able to be encoded .
it will ruin the file because you have to convert it to wav and re-encode it .
plus that is to low a bit rate for dts ..
plus the encoder is 1500$"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I wouldn't care if its low for dts but its still dts but the thing is 1500bucks
thats too much
just curious, which one is 1500 ? is the best? and does besweet able to do that?
so:
first: how to convert it to PCM Wav so no quality loss?
second: whats the best cheapest and fair quality option?
thanks for you reply btw -
DTS doesn't support 448 for 5.1
besweet - no
you might as well convert it to ac3 5.1 as it wouldnt mater much anyway (448 ac3 is going to sound better than 448DTS (which you cant do anyway) )
http://www.steinberg.net/en/ps/products/upcoming/dts_encoder/index.php?sid=0 (you need Nuendo also)
or
http://www.surcode.com/
if you convert it to wav - you will have quality loss when re-encoding as it is a lossy format ..
why would dts will be bad in lower bitrate? any information for DTS structure and comparison with ac3?
my knowledge isn't enough -
there is a comparison on both the dts and dolby web sites (with different results of course)
DTS uses a higher bit rate than dolby -- end of story .. i think it also sounds better , but it requires a higher bit rate to achive this ..
if ac3 were at the same bit rates -- it may also sound better ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
how about 556 kbps ? am I gonna be able to do that? I just want to make a bit of saving space for the audio
convert it to ac3 448 ....
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
