I recently purchased a dvd/cd-rw drive and installed it into the selectable bay of a Toshiba Tecra 8100, running windows 98. On startup I get an IDE ERROR 1 and the drive doesn't show up. If I remove and then reinsert the drive with the computer running the drive shows up and appears to run fine. When I restart the computer it's gone again.
When the drive is available it shows up under Device Manager as Driver: HL-DT-ST RW/DVD GCC-4241N; under Settings I have Firmware Rev: OH33 and Target ID 1; under options the "Disconnect" and "Auto Insert Notify" boxes are checked. I tried unchecking the "Disconnect" box but get the same result.
I tried running Install New Hardware from the Control Panel but no new devices are found.
Any suggestions on getting the drive to show up on startup without having to unplug and reinsert it would be greatly appreciated.
Does it show up in BIOS when booting? If not, you may need to set it to auto-detect, this is a BIOS option (press DEL when starting up the PC to get into your BIOS screen). I don't know what the "selectable bay" uses for protocol, is it IDE? It's not a USB or Firewire drive, is it? In any case, you should be able to see it if you check your BIOS, if not, there is something else going on.
Ethernet (n): something used to catch the etherbunny
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
Computer wonīt recognize DVD disk
By dexter30 in forum MediaReplies: 10Last Post: 4th Sep 2010, 14:52 -
drive won't recognize 8.5gb discs (udf?)
By aerogurl in forum MediaReplies: 29Last Post: 13th Feb 2010, 12:45 -
PC won't recognize burned files to DVD
By browndav in forum MediaReplies: 6Last Post: 9th Jan 2010, 15:43 -
DVD drives won't recognize any discs
By TIBGustaf in forum DVD & Blu-ray WritersReplies: 10Last Post: 3rd Jul 2007, 07:29
