I have a DVD file on my hard drive. I only want to save parts of some of the VOB files. What do I need to do to save smal clips as MPG fiels.
dvdshrink
https://www.videohelp.com/forum/userguides/198813.php
just read step1...and rename the vob to mpg. -
Baldrick
Thanks for the info. But that leave me with a huge mpg file.
I want to save part of the VOB file and have it a normal size MPG file. -
didn't you read the guide??? you can select exact what you want with dvd shrink.
if it is still huge, be sure to strip the audio tracks....and you can also shrink it.
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
remove audio part of mpg
By zmartha in forum AudioReplies: 5Last Post: 19th Oct 2009, 18:51 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
How to save converted *s2d.mpg in another folder???
By junkfood in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Sep 2007, 10:01
