Aloha peeps,
sorry if I'm being like really really noobish,but how do I burn a DVD
I'm using nero 6, and have the two filesconverted my AVI's with tmpg so I have the two files (mpg and wav) but what do I do with these now?? And how do I make a menu,
please help, I cant find a guide anywhere
thanx![]()
click on AUTHOR here to the left...23409834098 guides.
tmpgenc dvd author is my favorite. -
OK, I used tmpg to encode, then used tmpgenc dvd author to author, then I used nero to burn (following a guide on here) but hen when I play it, IT HAS NO SOUND.
I put all the files that tmpgenc dvd author created into the video_ts folder in nero, and burnt it, the menus and video is fine, but why is there no sound? what am i doin wrong?
The only thing that is different to the tutorials is that the files, created by tmpgenc dvd author are in two folders, labelled
volume 1 and volume 2
then in volume one there are two sub folders labelled AUDIO_TS and VIDEO_TSbut in volume 2 there is only one sub folder, labelled VIDEO_TS
what do I do with these files? -
when u tmpgenc'd the files did u get seperate video & audio or just 1 per movie half. sounds gotta be 48000 bits or watever.
u can use dvd lab to load up the 2 half movies, either with sound in 1 file or add it seperate to each movie, then compile as 1 movie.
gotta add a movie for part 2 in this and join em.
use a virtual drive to play the vob files in power dvd,to check sound pics ect.
saves wasting disks -
huh??? I just encoded 3 avis with tmpgenc, then put them together with a menu in tmpgenc dvd author, now i dont know what to do,
I had to put in the location of the video AND audio files when I uesd tmpgenc DVD author -
you can burn with tmpgenc dvd author, https://www.videohelp.com/forum/userguides/172123.php scroll down to the end of the guide.
I'm not trying to pay out on you or anything, but I think you need to read What is DVD...then read it again....Originally Posted by greer1988
and again....
and again until some of what is written there starts to make sense - I guarantee most of it won't when you first read it.
It sounds like something has gone amiss in the encoding stage if you don't have audio. As mentioned, if you still have the MPEG-2 files that you create with TMPGEnc Plus, try playing them on your computer. Does it have sound ?If in doubt, Google it.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
