HI I just got finished for my second time trying to encode a .wmv to an mpg2 file with TMPGenc plus. I used Lordsmurfs guide on his website. However, the output file created is an MS-DOS application and DVD compliant. It looks to be the right size...but wrong type of output file. Anyone have any problems with this or better yet, anyone have any ideas what I'm doing wrong? Help Please, I'm getting very frustrated!
okay, this may sound stupid, but how do I rename it? Should i just right click on it and go to rename and rename it there? Will a .mpg extension enable it to be put on a dvd?
For more help please fill in your profile. I cannt figure what the problem is. I have done this several times with no problem.
Exactly what is the file extension? What does the file properities show?
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 17:25 -
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 07:04 -
Have HD MKV file, would like HD output file
By StevoK in forum Video ConversionReplies: 3Last Post: 9th Feb 2010, 21:43 -
HD output problems after editing
By pszilard in forum EditingReplies: 5Last Post: 2nd Jan 2010, 14:47 -
AutoMKV output problems.
By SantinoSan in forum Video ConversionReplies: 0Last Post: 27th Mar 2009, 10:40
