Hello, I just purchaesd a lite-on 832s and tried to make my fist disc. I
kind of failed and would like suggestions if possible.
I used the latest version of nero, it said that it successfully created disc,
when I played it my Sony SLV-D500P stand alone it played erratically, lots
of artifacts and sound was jumpy. I played it on my computer, no artifacts
but I had no sound either. I tried to burn it in copy to dvd but that kept
failing to initialize, luckily it didn't ruin my disc. I changed the book type to
dvd rom, hoping that this may make the disc more compatible, but this might be my problem, I only have one more disc and really don't want to ruin another one because they are cost prohibitive at the moment.
I have the latest firmware fron lite-on installed, and used their book tool for changing book type.
Any help or suggestions would be greatly appreciated, thanks
Bad move buying that writer. Should have given it more time before they work out the issues with those. Second thing is those blanks are way too expensive.
To back up a commercial DVD is not even worth it. Probably better to buy 2 copies of everything which defeats the purpose.
There is a sucker born every day."There's a sucker born every minute" -
It was only $80 or so, so I figured that I would give it a try.
My 2 discs came as promos from Newegg, so it really didn't
cost anything to try - discwise that is!
Ps this writer got good reviews! I chose this one over the NEC -
the problem is the dual layer mania.....a lot of problems for now, just as it was the single ones a while ago.
give it some time, the disc are way to expensive to experiment it.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
Problems with Dual Layer disk burning.
By qaa in forum Newbie / General discussionsReplies: 19Last Post: 21st Apr 2008, 02:47 -
Dual Layer problems
By cloudsdestiny in forum DVD RippingReplies: 4Last Post: 30th Dec 2007, 02:23
