I have a Adaptec VideoOh 2010 pci capture card and would like from anyone else that may have one if they are using any other software other than the mydvd v4.5.2 and if so how did you get it to work. I just dont like the mydvd cause of its lack of options for capturing
any help from other users is great thank you
Advice: Use something other than "I would like some advice" in your subject line. Just trying to be helpful
concidering you took the time to read it then, thanks for the scarcastic advice and no help at all
Actually trying to give you good advice.... I can't comment on your question because I don't know. Most likley there is someone that does though. Putting better info such as the card you want acvice on in your subject line will grab there attention.
Here's a topic:
"Alternative to myDVD with Adaptec VideoOh 2010 pci capture card"
thecoalman, like me, was probably fed up with the proliferation of "help me!" and "dseperate..." topics.
Try Ulead Movie Factory. I've had great results with it, even with a cheap Pinnacle Studio card. -
Did you try the well known alternatives?
Virtualvcr, Virtualdub....
New PC advice
By garryward in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 13:27 -
New PC advice
By neworldman in forum ComputerReplies: 14Last Post: 19th Feb 2010, 10:17 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
I need some advice
By CM World in forum MediaReplies: 1Last Post: 6th Aug 2007, 05:58
