I have a ASF file that is 2hrs long.. I want to burn the movie into VCD format.. however when I tried burning it using Virtual Dub 1.3c, the estimated file size was 6 GIG!!! How do I go about converting such a ASF file into VCD format? The asf file is 200++ meg big ... Kindly assist![]()
You did not use a compression, look for video compression (I don't have VDub on this comp.) and select DivX or what you want... The audio is probably left on uncompressed (Default)...
I'll post later today if more help is needed, gotta check VDub...
But check as I wrote, look for The Video Compression and allways Full Processing mode!!!
Magnus Jensen
A.K.A Geezus -
Thx !! Now I know the problem... but I found 2 DIVX codec compression .. DIVX 3 and DIVX 4 which should I use?
Not sure, I've never used DIVX4...
But you could try a little with both of the codecs...
The best thing is to experiment...
Magnus Jensen
A.K.A Geezus
Converting into ASF [Optional Setting]
By ashkan_vpm2 in forum Video ConversionReplies: 0Last Post: 15th Feb 2010, 07:17 -
converting asf to avi
By projecttemp in forum Video ConversionReplies: 2Last Post: 3rd Aug 2008, 08:40 -
converting asf to avi problem
By konig in forum Video ConversionReplies: 1Last Post: 6th Mar 2008, 15:37 -
Converting an ASF (WMV) file
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 06:16 -
Problem converting ASF to AVI/MP4
By yohu123 in forum Video ConversionReplies: 11Last Post: 16th Sep 2007, 12:24
