Results 1 to 12 of 12
  1. anyone have a problem with return of the king? ive tried to make a vcd outta this dvd as a back up and can only get video--no audio. the programs i use are: dvddecrypter in ifo mode, dvd2avi outputting the audio as a wav file and tmpgenc. ive tried the same method, settings etc with other dvd's and had no problem. i was wondering if rotk had some sneaky encryption. thanx
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    nope
    but what a waste of a movie to convert it to vcd ..
  3. im in the process of making a lord of the rings "complete" dvd and this is one of the stages. ive already done it but the last movie has no sound so when i get this sorted it'll be an epic - not a waste of a movie...
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    vcd a epic ?
    9 hours on a dvd ?
  5. yup, 6 vcd's all made with a 1 disc template in tmpgenc then reauthored with tmpgenc dvd author and ran thru dvdshrink reathor mode. tried it once and it worked just fine with a quality a little better than vhs.
  6. Member Grimey's Avatar
    May 2004
    Canada Eh?
    Hmm....I find it hard to believe that you can fit 9.5 hours of video on a dvd at better than vhs quality.
  7. absolutely true, i,ve been working on it for a while now and finally got a good result, chapters and all.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Try playing this WAV file on its own.
    Are you muxing the audio using TMPGenc or TMPGEnc DVD Author ?
    Why DVD Shrink's Re-Author mode ? Wouldn't you just do Full Disc ?
    If in doubt, Google it.
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I think if you cut the audio down to about 128kbps, use 2-Pass VBR encoding, VCD res, and ran the output through Shrink you could quite possibly get something half-decent to look at.
  10. managed to get the audio sorted by extracting as a wav using xmpeg then remuxing in tmpgenc with the video. strange though, i've never had this problem before and it still annoys me why it happened. the way i done this dvd is by using a 1 disc template in tmpgenc and dropping the audio like you say to 128kb/s. i cut each film in half and set the disc size to 74min at 98% of capacit, then reauthored the resulting mpegs to make vob files. the reason i reauthored again using "shrnk" was to make sure i could get it all on 1 dvdr. the quality like i say is more than acceptable.
  11. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I reckon you've gone the long way about it, but kudos for trying !
    It's probably one of those self-discovery type projects anyway I guess.
  12. thanx bro, i reckon i must be the only person on the planet with this! still never got my original question answered though!
